How to repair chipped bricks?
Hey Community,
I wanted to ask how I would go about repairing these 2 chipped bricks near our garage doorway?
If this can be done as a DIY option or would I need to hire a professional to fix this?
Cheers,
Re: How to repair chipped bricks?
Welcome to the Bunnings Workshop community @DeeM91. It's great to have you join us.
Do you have replacement bricks of the same style and shape? I imagine the best course of action would be to remove these damaged bricks and replace them, but if you don't have spares then matching could be a challenge.
Next best option - do you have the chips that came out when the damage occurred?
Please let us know and we can help with next steps.
Thanks,
Thank you Jason for the welcome and your reply!
I don't have any spares to replace the bricks or the chipped damaged pieces because it originally it done by a tradie working on our place and they have cleaned everything up so I could not salvage it.
Would you recommend get both bricks replaced would you say?
Hello @DeeM91
Thanks for sharing your question about how to repair your chipped bricks. For this type of repair, I often suggest using Dingo Fast Set Mortar in combination with Dulux Avista Oxide 1kg Brick Red Cement. Since you are only patching a small portion, I recommend not adding too much oxide to the mix, your goal is to get that pale brick colour you currently have.
I recommend using a 1 litre plastic container to mix a bit of the mortar and oxide together while they are dry. Once you fully mixed you can then add water to it. You're after a toothpaste like consistency so that the mortar will keep its shape too much water will make it slurry. You'll also need a Craftright 150mm Pointing Trowel to spread the patch evenly.
Thank you @EricL! for your help and instructions we will follow your advice and do this at home and give it a go.
