How to fit 30mm arbor blade on Bosch circular saw?
alvindmello
Community Newcomer
Hi all,
I am trying to fit a 184mm circular saw blade with an arbor of 30mm on the Bosch 140
https://www.bunnings.com.au/bosch-professional-1400w-184mm-circular-saw-06016b3040_p0237205?store=80...
With the 30mm to 20mm reducers as well it just does not fit like the other saws I see on YouTube. The mounting flange seems to only support upto 30mm
Is there a technique to this ?
Re: How to fit 30mm arbor blade on Bosch circular saw?
Hi @alvindmello,
A 30mm bore is quite large for a 184mm blade. 30mm bores are more commonly seen on 254mm blades, so it's a bit unusual to see one on an 184mm blade or have a need to adapt one.
The vast majority of our 184mm blades come with a 20mm bore, which will suit the Bosch GKS 140. For example, the IRWIN 184mm 64T Marathon Pro Multi Material Circular Saw Blade will not need a bush and will provide the 64 teeth you require.
Can you let us know what blade it is and if there's a possibility of returning it and using one of the several available off the shelf with the correct sized 20mm bore?
I had this blade lying around and thought it worked with 185mm Makita and other brands.
Makita 185mm (7-1/4") x 60T TCT Multi Purpose Saw Blade - D-63622
Thanks for clarifying. I was not sure if there is some other technique to use 30mm bore size blades on the Bosch that might have been different from other brands.
I think that the blade you have with the extra large bore size is likely too large for the typical 184mm circular saw @alvindmello. As mentioned, most of our 184mm blades have 20mm bores, the 210mm have 25mm and the 254mm start to have the 30mm. The blade you have, even with the bush, might just have a bore size too large for the Bosch's mounting flange.
Solved. Got another one you mentioned Mitchell with 20mm bore. All good and thank you.
