How to build a folding table?
murjenn44
Folder table 2ft 6 inches wide 5ft long 2ft 6 inches high to be used for paint pouring in a small workshop
murjenn44
Re: Folder table showing measurements ?
I need  to see a folding Table with the measurements shown above.
Welcome to the Bunnings Workshop community @murjenn44. It's great to have you join us, and many thanks for your question about folding tables.
Have you checked out our range of folding tables? Most plastic folding tables are 60cm (2ft) wide, but the closest in length would be the 4ft or 6ft versions. There's nothing right on 5ft. If you need those exact measurements, perhaps you could have a sheet of 15mm plywood cut down to that size. You could then screw it to the top of a 4ft table with adjustable height legs. That way, you'll have the correct sized top and legs that can be set at 61cm (2ft) high.
Let me know what you think and if you have any questions.
