Does Bunnings cut wood to size?
  • Panel saw – used to cut large sheet materials into smaller rectangular sections and pieces. The machine is capable of both horizontal and vertical cuts on most of our board products. Some examples of products that can be cut using a panel saw include MelaminePlywood and MDF.
  • Mobile device - Select your nearest store and then click on your store's name on the top left of the screen. This will take you to your store's information page, including details about what services they offer
  • Desktop computer - Type the nearest store's name in the change store drop-down and then click on store details. This will take you to your store's information page, including details on what services they offer.
We offer a number of options to get your products home safely. You can use our free courtesy trailer for up to two hours. If you need more time you can also hire a trailer, a ute or a van to suit your needs. We also offer a comprehensive delivery service to assist you in getting your purchases home. Most stores offer same day or next day service. Please contact your nearest store for details.
  • Cuts to timber and panels boards are rounded up off to 100mm increments. We are unable to do precision cuts.
  • Minimum length of cut timber is 600mm
  • Customer are required to purchase an remaining offcuts measuring less than 1800mm
  • Multiple timber cuts may incur a charge of $1 per cut.
Peedee
cut to size, aluminium
Will Bunnings cut their aluminium sheeting to size?
Re: cut to size, aluminium
Hi @Peedee,
Unfortunately no, this is not a service that Bunnings offer.
Depending on the thickness of the sheeting, you can usually just use aviation snips.
If it is a bit thicker, an angle grinder with a cut-off wheel is the way to go.
rubymoon05
Re: Does Bunnings cut wood to size?
Im looking at purchasing special order particle board , is that able to be cut in metre lengths?
cujones50
Community Newcomer
Cutting service for shelving
Does Bunnings Springvale provide a cutting service for shelving, e.g. cutting to required length?
Re: Cutting service for shelving
Hi @cujones50,
Bunnings Springvale offer a cutting service, however we do not offer precision cuts.
You can have your materials cut to the nearest 100mm for ease of transport, but you will need to make precision cuts yourself.
We are more than happy to offer guidance on how to do this yourself. If you'd like some advice, please don't hesitate to reach out.
Let me know if there is anything I can assist with.
