Does Bunnings cut wood to size?
Many Bunnings stores offer a timber cutting service to help you get your wood home and get started on your project.
Here are some frequently asked questions about our timber cutting service to help Bunnings Workshop members.
What type of cuts can be done at a Bunnings store?
Bunnings stores typically have two types of saws for timber cutting.
  • Panel saw – used to cut large sheet materials into smaller rectangular sections and pieces. The machine is capable of both horizontal and vertical cuts on most of our board products. Some examples of products that can be cut using a panel saw include MelaminePlywood and MDF.
Is this service available at my local Bunnings?
You can check whether the timber cutting service is available at a nearby store by visiting the Bunnings website. Here’s how:
  • Mobile device - Select your nearest store and then click on your store's name on the top left of the screen. This will take you to your store's information page, including details about what services they offer
  • Desktop computer - Type the nearest store's name in the change store drop-down and then click on store details. This will take you to your store's information page, including details on what services they offer.
Can I bring my own piece of timber to be cut?
Due to the many variables associated with timber products, we can only cut products purchased from our stores.
When is the best time to visit a store for timber cutting?
Visiting at a quieter time will ensure faster service. It's best to avoid weekends and public holidays as many other D.I.Y. enthusiasts will also be looking to build their own projects.
What if I want to do the cutting at home?
Knowing what saw to use and how to use it is the key to success. Here are some useful guides to get you started:
What if I can't get my timber home?
We offer a number of options to get your products home safely. You can use our free courtesy trailer for up to two hours. If you need more time you can also hire a trailer, a ute or a van to suit your needs. We also offer a comprehensive delivery service to assist you in getting your purchases home. Most stores offer same day or next day service. Please contact your nearest store for details.
Update 14/08/2024: The Bunnings team have provided the following information on our cutting service.
  • Cuts to timber and panels boards are rounded up off to 100mm increments. We are unable to do precision cuts.
  • Minimum length of cut timber is 600mm
  • Customer are required to purchase an remaining offcuts measuring less than 1800mm
  • Multiple timber cuts may incur a charge of $1 per cut.
As always, our helpful members are ready to assist with any questions you have on completing precision cuts for your D.I.Y. projects at home.
Please feel free to let me know if you have further questions about our helpful timber cutting service.
Peedee
cut to size, aluminium
Will Bunnings cut their aluminium sheeting to size?
Re: cut to size, aluminium
Hi @Peedee,
Unfortunately no, this is not a service that Bunnings offer.
Depending on the thickness of the sheeting, you can usually just use aviation snips.
If it is a bit thicker, an angle grinder with a cut-off wheel is the way to go.
rubymoon05
Re: Does Bunnings cut wood to size?
Im looking at purchasing special order particle board , is that able to be cut in metre lengths?
cujones50
Cutting service for shelving
Does Bunnings Springvale provide a cutting service for shelving, e.g. cutting to required length?
Re: Cutting service for shelving
Hi @cujones50,
Bunnings Springvale offer a cutting service, however we do not offer precision cuts.
You can have your materials cut to the nearest 100mm for ease of transport, but you will need to make precision cuts yourself.
We are more than happy to offer guidance on how to do this yourself. If you'd like some advice, please don't hesitate to reach out.
Let me know if there is anything I can assist with.
adamjohns
Hi Mitchell,
Wondering if instore cuts can be done on Bunnings purchased magnum board (I/N: 0182471)?
Your advice is greatly appreciated!
AJ
Welcome to the Bunnings Workshop community @adamjohns. It's sensational to have you join us, and many thanks for your question about our cut shop.
Unfortunately, we can only cut timber on our machines and don’t cut timber composite materials like Magnum Board. However, it can be easily cut with a score and snap knife.
