Where to find toilet pan collar locking ring?
I need a new locking ring for the toilet pan rubber collar. I have new rubber but can't find locking ring on your website?? Cheers Glenn
Re: toilet pan collar locking ring
Hello @Glen123456
Welcome to the Bunnings Worshop community. It's sensational to have you join us and thanks for sharing your question about getting a new pan collar locking ring.
Unfortunately, the pan collar locking ring is not sold as a separate item. It comes as a complete set like the Holman 100mm DWV PVC Standard Pan Collar. The reason for this is that they are compatible only with each other. Unfortunately, there is no fixed standardized size for pan collar locking rings.
The standardized parts for say Holman will only fit Holman products. The Kinetic trap adaptor for example has its own set of fittings and if the locking collar should fit a Holman set it would just be out of coincidence. I propose removing your old pan collar and installing a new one.
Well that's a shame, as you sell the rubber which sits inside the ring. Anyway I had bought an offset complete unit, I was able to pull apart, and retrieve ring of that. So locking ring and collar fitted beautifully over my existing trap. 🤗
Hi @Glen123456
That is fantastic to hear, I'm glad the locking ring worked with your existing pan collar.
Subject | Author | Posted | |
February 2022 | |||
October | |||
October 2021 | |||
July 2021 | |||
May 2023 |
