What dimensions for Estilo Semi Frameless Shower screen?
Would anyone be able to advise the internal measurement of the shower return panel (fixed) from the face of the shower wall to the inside of the door panel once installed. The dimensions shown on documentation appear to be the outside dimensions. I intend to fit this screen onto an existing tiled shower hob and need to check it will align correctly with the inside of the hob.
- Labels:
Renovation
Tools and Materials
Re: Estilo Semi Frameless Shower screen with return installation
Hello @Gumknuckle
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about installing an Estillo semi frameless shower.
The return also referred to as the fixed panel has an adjustable measurement of 855mm to 880mm. According to the instructions this is from the wall corner to the edge of the wall post. Please keep in mind that this panel has been designed to fit inside a 900mm x 900mm shower tray with a 10mm++ lip. The inside section of the tray would be around 890mm on both the door and fixed side. If your shower hobs measurements are within 890mm x 890mm then the shower frame will fit inside.
However, please keep in mind that if the shower hob is too deep it will interfere with the opening of the door. I've placed an image from the instruction manual from page 5 that shows you the maximum measurements the shower panels can be adjusted to. If you wish to physically see the shower, I suggest visiting one of the larger stores in your area and having a look at the shower display.
Subject | Author | Posted | |
February 2023 | |||
March | |||
February 2024 | |||
October 2022 | |||
August 2023 |
