Hello,
I am converting an existing room into a laundry/toilet/bathroom (I am keeping the shower in the same place).
My concern is having floorboards (on a slab) in a wet area.
Ideally would rip up the floors and tile but budget won't allow. Any other ideas?
I was thinking micro cement.
Jerry
Hello @Jerreemon
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about flooring ideas.
I propose removing your timber flooring and replacing it with Hybrid Flooring Planks. It's 100 percent waterproof and can be installed in high moisture areas including kitchens, laundries and bathrooms. Please note that this flooring can't be installed inside the shower cubicle itself. There is also the option of installing Vinyl Sheeting, the timber flooring will need to be removed before the vinyl sheeting is laid down on the concrete floor.
Aside from tiles, these are the only materials I can think of that are strong enough to withstand the heavy moisture of the bathroom area.
Hi @Jerreemon
What @EricL has suggested is an excellent solution. The only other one other than tiles which are out is to polish the slab floor if you like that look. You can hire concrete polishers and then protect it with a non-slip sealant.
Evening @Jerreemon
Mmmmm I will have to bow out on knowledge of this one, I would also suggest to follow @EricL 's suggestions as he is a wealth of knowledge
Hi @Jerreemon,
I just wanted to touch on whether the floor area outside the shower cubicle has had a waterproofing membrane applied under the timber flooring as per building standards for wet areas. It's something to bear in mind if you are adding additional flooring. Although the Hybrid Vinyl Planks @EricL has suggested are waterproof, they do not exempt the substrate from needing a waterproof membrane.
I just wanted to raise this in case the area hasn't been waterproofed under the timber flooring as it could cause a headache in the future if you needed to pull everything up to apply one.
Hi All,
Bit of an update to an older post.
Our home has a quirky room out the back which the previous owners added a shower into it, which is on a lower level to the whole house. Access is done via outside the house.
I am going to convert this to a laundry/bathroom, keeping the shower and installing a sink and toilet in the room. This photo is a bit of an old 1, the shower has a shower door which fully encloses the shower.
I know it's not ideal to have floorboards in a wet area, although this shower will be more of a guest shower, so won't get much use.
Budget doesn't allow for the floorboards to be ripped up, new subfloor and then tiled, although I know this is preferred.
What options do I have for flooring?
The floorboards are in a good condition with no moisture damage as the shower in this space has never been used.
Vinyl over the top?
Thanks in advance for your help!
Good Evening @Jerreemon
My mums bathroom is a Lino/vinyl and has held up nicely over the past 7-8 years since she had the old one replaced.
Hi @Jerreemon,
Thank you for your question.
Unfortunately, if you were to convert this space to a bathroom, to fit in line with the National Construction Code Part 10.2 Wet area waterproofing and Australian Standards AS 3740 (Waterproofing of Wet Areas), you would need to reline the room with a suitable fibre cement product such as Villaboard, apply a waterproof membrane and then put an appropriate floor covering over the top. Luckily, there is no need to remove the existing hardwood flooring, but you will need to attach fibre cement sheeting over the top.
I understand that this may be outside of your budget, but I can't recommend moving forward with this project without the necessary waterproofing in place.
Without these steps, there is no flooring solution that I can recommend that would make the room in line with the relevant standards and codes.
If the room was lined and waterproofed, you could use hybrid waterproof flooring or vinyl sheeting outside of the shower, or you could tile the room.
Allow me to tag some of our helpful members to see if they have any advice to offer, @Nailbag, @Jewelleryrescue, @Adam_W.
