Hello,
I am converting an existing room into a laundry/toilet/bathroom (I am keeping the shower in the same place).
My concern is having floorboards (on a slab) in a wet area.
Ideally would rip up the floors and tile but budget won't allow. Any other ideas?
I was thinking micro cement.
Cheers,
Jerry
Hello @Jerreemon
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about flooring ideas.
I propose removing your timber flooring and replacing it with Hybrid Flooring Planks. It's 100 percent waterproof and can be installed in high moisture areas including kitchens, laundries and bathrooms. Please note that this flooring can't be installed inside the shower cubicle itself. There is also the option of installing Vinyl Sheeting, the timber flooring will need to be removed before the vinyl sheeting is laid down on the concrete floor.
Aside from tiles, these are the only materials I can think of that are strong enough to withstand the heavy moisture of the bathroom area.
Hi @Jerreemon
What @EricL has suggested is an excellent solution. The only other one other than tiles which are out is to polish the slab floor if you like that look. You can hire concrete polishers and then protect it with a non-slip sealant.
Evening @Jerreemon
Mmmmm I will have to bow out on knowledge of this one, I would also suggest to follow @EricL 's suggestions as he is a wealth of knowledge
Hi @Jerreemon,
I just wanted to touch on whether the floor area outside the shower cubicle has had a waterproofing membrane applied under the timber flooring as per building standards for wet areas. It's something to bear in mind if you are adding additional flooring. Although the Hybrid Vinyl Planks @EricL has suggested are waterproof, they do not exempt the substrate from needing a waterproof membrane.
I just wanted to raise this in case the area hasn't been waterproofed under the timber flooring as it could cause a headache in the future if you needed to pull everything up to apply one.
