How to replace taps with the same size?
michael1972
I want to change old style taps e.g, everyday unscrewers for the ones the Caroma luna lever style. How do you measure to make sure you have correct tap? Is it from the wall to the tip of the protruding tap valve? Don't want to do two trips. Also, do you use the current tap valves or are different ones necessary?
