How to open a metal plumping pipe cap?
Michael11
Cultivating a Following
Hello,
I was wondering whether anyone had advice on what tool to use and how to open the metal plumping pipe cap pictured to unclog the pipe?
A while back a plumber opened the cap (but I can't remember what tool he used) and then ran a garden hose (without the nozzle) down the pipe, turned on the water, and this removed debris etc that was causing the blockage, so I was hoping to potentially give it a go first and see if that resolves the problem before calling the plumber.
Any suggestions/guidance would be greatly appreciated.
Thanks again,
Michael
Metal plumbing pipe capMetal plumbing pipe cap
Noyade
Re: How to open a metal plumping pipe cap?
Afternoon Michael @Michael11
Possibly a tool like this is required...
Drain Plug Remover
Michael11
Thanks so much Noyade - this is really helpful!
Hello @Michael11
Just to add to the suggestion made, I also recommend using a Trojan 250mm Multigrip Plier to hold on to the sides of the drain plug. The Multigrip plier has an adjustable mouth that will allow it to grip onto the outer edge of the plug allowing you to turn it.
Michael11
Thanks Eric for the helpful suggestion - really appreciate it!
wikiwiki
How did you go with getting this open?
Welcome to the Bunnings Workshop community @wikiwiki. It's fabulous to have you join us, and many thanks for jumping into the discussion.
Let me mention @Michael11 so they are alerted to your question.
Do you have a similar access point that you need to open? Feel free to post some pictures, and I trust our helpful members will have some suggestions for you. Let me know if you need a hand uploading images.
