How to fix the rotten flooring in the bathroom?
mike1360
Building a Reputation
I recently found my shower tray is cracked and the water had damaged the floorboard and a small section of the floorboard is rotten, What should I in this situation? Should I hire a builder and re-do the entire bathroom?
Re: How to fix the rotten flooring in the bathroom
Hello @mike1360
Thanks for sharing your question about repairing your bathroom flooring. Looking at the picture you posted it seems that the damage is not that bad. However, I still recommend engaging the services of a registered builder. They will be able to determine if the damage can be patched or if the entire flooring area needs to be replaced.
Please keep in mind that waterproofing might be necessary even if you are using a polycarbonate shower wall. Please double check with your builder and the local council on the rules and regulations for a shower repair.
If you do decide to revamp your bathroom area, please make sure to check out our Top 10 most popular bathroom projects and How to plan a bathroom renovation by @Adam_W
mike1360
Thank you Eric, I've had a building inspector to do an inspection on it. He recommended to fill the void with gorilla filler
Please let us know if you have further questions @mike1360 or need advice on how to proceed with the repair.
