How to fix loose laundry sink tap?
razzamakazz
Hi ...I think my laundry sink tap has seen better days
..how do I fix ...do I need to get a whole new tap.. or just the black/brown thing holding it up..
..cheers..Kaz
Re: Laundy sink tap is pretty well dead
Good Evening @razzamakazz
Want to hear something funny? I have the same issue lol Mine hasnt lost the nut on the underside totally yet but its loose.
If you look under your sink where the tap is, you will hopefully find something that looks like panel 5, 6 and 7 of the install guide. I am not sure its the same tap as yours but it shows what you can do to tighten it back up.
Mondella Cadenza 35mm Chrome Lever Kitchen Sink Mixer - WELS 4 Star 7.5L/min - Chrome  And then scroll down to guides and documents and open the installation guide. Instalation guide and also Specification will show you the profile of a similar looking tap.
There hopefully will be either a loose nut in the cupboard or still on the tap underside itself. It will be a tight spot probarlly to get into (hence why I havnt tightened my tap) You could use your phone camera to take a video and see if it makes sense or just some photos.
It does look like the rubber washer that it rests on has perished so you may need to get a replacement washer.
I would take some photos of your tap itself and post it here so the Bunnings crew @JacobZ and @MitchellMc or @EricL will be able to determine if they know the model of your tap.
Hi @razzamakazz,
If you check under the cabinet, what do you see?
@Dave-1 has already provided some fantastic advice, which explains things nicely.
You should be able to just tighten up the fixing nut, but if there are any issues with it, it can be replaced with this Kinetic Mixer Tap Fixing Kit.
There is not a specific washer for underneath the tap body, but you may be able to find a suitable replacement in this Kinetic Assorted Sizes O Ring Kit.
Let me know what you think and if you have further questions, please don't hesitate to reach out.
Thankyou and yo DAVE1 as well..both nuts are still on so I'm just going to need a new washer this one is totalled...I will pop into Bunnings tomorrow and get a new one..thanks again
Hi Jacob
I've looked underneath the sink haven't found any nuts at all .but I looked again at the actual tap and both pipes leading to hot and cold water taps are still there...I'm going to undo the whole thing as the washer is totally destroyed..thank you for your help and yes Dave was really helpful too...I'm going to pop into Bunnings tomorrow with one of my tiles and the tap and get them all sorted out...I really like being on the workshop site..so many helpful people..many thanks
Kaz😊
