How to fix a leaking Bosch Awua stop hose?
piyushmailbox
Hi  I have a Bosch washing machine whose aqua stop valve is leaking water; dies it need replacement or washer fix ?
Re: bosch awua stop hose leaking
Hello @piyushmailbox
Welcome to the Bunnings Workshop community. It's marvellous to have you join us and thanks for sharing your question about your washing machine hose.
Because the leak is between the head and the hose, it can't be repaired and must be replaced. I suggest bringing your hose to the store and going to the plumbing department. Show the hose to the plumbing specialist and they will make sure that you get the correct type of hose.
I also suggest having a look at the BOSTON 2m Burst Alert Washing Machine Inlet Hose. It is a dual layer hose and protects your home from flooding.
