How do you put the clothes dryer on the wall in Kaboodle software?
how do you put the clothes dryer on the wall i.e. raise it off the floor 900mm
- Labels:
Renovation
Tools and Materials
Re: how do you put the clothes dryer on the wall i.e. raise it off the floor 900mm
Hello @norelad
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about your clothes dryer.
The general steps are to locate the studs in your wall and use these as an anchor point for the dryers mounting bracket. Sometimes the studs are out of place, and it may be necessary to attach a horizontal piece of timber onto the studs so that the mounting bracket can be anchored properly into place. Depending on the type of substrate you are mounting onto there are a number of techniques that you can use.
Below are the discussions our members have had in regards to mounting dryers to different materials:
- Solved: How to mount dryer with no studs? by @bect73
- How to add a wall mounted dryer? by @rp2114
- How to mount dryer on double brick wall? by @KayJee
- How to mount dryer to laundry wall in apartment by @laurenvan
- How to mount a clothes dryer to a tiled wall by @Dandinelle
However, if you're mounting wall is unique and is non-standard, please let us know and we will offer other suggestions on how to mount your clothes dryer.
Re: How do you put the clothes dryer on the wall in Kaboodle software?
Hello @norelad
My apologies, I misread the end of your question. The Kaboodle kitchen design software does not have an off floor mounting option for the dishwasher. However, in the appliance's menu, I suggest clicking on the custom appliance's icon and using the resizable microwave as a stand in for the dryer. The microwave can be resized to the standard dimensions of a clothes dryer and can be relocated anywhere on the wall vertically or horizontally.
Hi I was successful at installing my dryer onto internal wall. It has had several uses and it is very securely fitted.
Bec
Subject | Author | Posted | |
February | |||
October | |||
October 2022 | |||
September | |||
December |
