We currently move to a new place and try to connect our front load washing machine waste to the pipe underneath the laundry sink (photo 1). However, we don't another spigot to connect the washing waste. Currently we have one spigot and it is connected to the heat pump dryer waste. It has a waste whole on the top of the sink, but there is no space to put the washing machines on the right to connect to that whole. We have a bench in our laudry which only give me an opinion of connect to the pipe underneath the sink.
My aim is to make another whole to connect the washing machine waste to the pipe.
I am thinking of taking out a part of the pipe (blue part- picture 2) and use a connection from the PVC to washing machines to the connect the waste Washing machine tub.
I found other people's pipe photo on the internet with the connection that I am looking for to buy (red part- photo 3) but I am can't find anywhere to buy this type of connection.
My question are:
- Do you think this will work?
- Does Bunnings sell that connection or any alternative connection that I can buy to connection between pvc to washing machine hose?
Our washing machine hose is 30-31mm
Thank you
Hi @Tamdaolam,
A warm welcome to the Bunnings Workshop community and thank you for your question about connecting a waste hose in your new home.
Can you advise what the diameter of the PVC pipes is?
Generally, they will be 50mm, in which case you can use this Caroma 50mm Garbage Disposal Trap Adaptor With Dishwasher Connection.
You may get lucky, and everything will line up so you can simply unscrew and replace this piece before screwing everything back together.
If this is not the case, you will need a plumber to assist you with modifying and installing new pipes.
Once this tee piece has been changed, you can connect your washing machine's waste hose to the spigot on the new tee piece. Check out How to connect a dishwasher for an easy-to-follow guide.
Hi Jacob,
Thanks for your reply and suggestion.
I am not sure which part that I need to measure so I did few measurements.
I took the blue part out (photo 2 in the previous post)
- I can't measure the other end which I need to connect to as I can't see the measure. So I measured the opposite pipe (photo 2)- it is around 43mm
- The connection to the pipe (photo 3) - it is around 48mm
- The pipe which was connected between them is around 34mm (photo 4)
Does the 50cm PVC connection work?
Thanks,
Hi @Tamdaolam,
Upon review, this Caroma 50mm Double Bowl Connector is likely a better option as it is stocked in many of our stores whereas the one I previously recommended is a Special-Order item. This means you can take your pipe in-store to compare and ensure they will work together.
It is worth bringing the piece you've removed in-store to compare. I'm sure the Plumbing team at your local store would be happy to help confirm compatibility. Showing them, your photos will also help.
I've indicated the measurements that will be important below.
As long as the thread connections I have highlighted above are the same diameter, it should work fine.
From the connecting pieces you've measured, it seems like the 50mm connector will work.
Thanks. I will give it a try.
Hi Jacob,
I went to Bunnings with the piece. Bunning staff couldn't find the piece that matches my piece. I ended up buying this instead as recommended by Bunnings staff https://www.bunnings.com.au/holman-50mm-s-p-trap-combo-set_p0503457
I changed the pipe and it looks good- like what I need (2 waste holes- photo attached). However, after running the water test from the tap, water just pull out from the two spigots even with a low water run. It does't happen like this with the old trap.
Do you know why the water is pulled out from the two spigots and do you know how to fix this ?
Hi @Tamdaolam,
When you tested the water, was it coming down from the sink above? Or through the discharge hoses that are attached to the spigots?
These spigots often come closed requiring you to drill them out for use. If the water is coming from the hoses, then this is likely the issue. If this is the case, you'll have to drill down through the spigot to open them up. Check out step 4 in How to connect a dishwasher.
If the water is coming up and out of the spigots, I suspect the top spigot is more likely the issue. A hose on the outside of the spigot with a clamp will create a better seal than one that is inserted in the spigot. If you can change the top hose so it sits over the spigot and can be tightened with a screw clamp, then this will likely solve the issue.
If either of these solutions don't fix the issue, you may need to speak with a plumber for their assistance.
Hi Jacob,
When I tested the water, it was coming down from the sink above with the sink tap running.
The set that I bought, it has already had wholes on that two spigots. It came with a plug, I took the plug out and there is a hole on each spigot for me to connect to the dryer and washer. I used the clamp for washer, but the dryer hose fits inside the spigot so I can't use a clamp.
The water pulled out from two spigots.
I think the pipe from the P shape doesn't push the water up to drain quickly enough (even on the slow water run). That is why the water fills up to the spigots and escapes from there. That is strange as this doesn't happen to my old P shape pipe with one spigot. I swapped back to my old pipe and the water flowed ok. Can this be product's fault?
Thanks,
Hello @Tamdaolam
I just want to be sure you drilled the spigots with a large drill bit, yes? Sometimes if the drain hole in the spigot is not drilled properly water will either drain slowly or it will return. In regards to the dryers drain hose an adapter must be purchased to reduce the size so that you can clamp the dryers drain hose.
Please double check and let me know if the spigot is properly drilled.
Hi Eric,
Luckily I don't need to drill the hole for the spigots on the product that I bought as it has hole in there already. I only need to unplug the cap and it is ready to connect so the whole shouldn't be the issue.
When the sink tap turns on, the water fills the pipe from the bottom up. The first washer spigot is struggle first (even with a clamp), then the dryer spigot next.
