How to mount flatpax cabinet to brick?
dan_
Flatpax cabinets have wall mounting requirements for timber stud wall but mention to seek advice from hardware specialist if mounting into brick.
What is the fixing procedure into brick walls?
Re: Flatpax Cabinet mounting
Hello @dan_
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about your Flatpax wall cabinet.
Whan mounting a wall cabinet on a brick wall, I suggest using Ramset 7 x 50mm Green Wall Plugs combined with Zenith 10G x 60mm Zinc Plated Hinge-Long Thread Timber Screws - 50 Pack. I recommend a minimum of six screws to a maximum of nine screws evenly spaced and spread out on the back panel of the cabinet. You can also look at using Ramset 10 x 75mm DynaBolt Plus Hex Nut Bolts to anchor the cabinet to the brick wall.
