Can I replace my shower head? And which part can I replace?
elzicorn
Hello,
we just moved into a new house that only has a shower, with a toddler who hates getting his head wet. Not a great combo.
So I’m looking to change the shower head as it is currently a pretty old rain shower head, so a hand held shower head or a more adjustable shower head might be preferable with the 2 year old!
My question is, are all shower heads replaceable? Can I replace mine (photos attached) and by myself possibly? And if yes, can I replace it at the wall? Or does it have to be on the end of the pipe (excuse me if my lingo is wrong, I’m new to all this).
thank you for any help and advice you are able to give! :smile:
Jewelleryrescue
Re: Can I replace my shower head? And which part can I replace?
Hi @elzicorn
1 The round  shower head will unscrew and is  readialy replacable.
2 The  hose pipe coming out of the wall is also unscrewable and interchangable with other shower accessories.
A couple of  ideas to get you started,
The simplest solution  is a single function hand set,  Unscrew the pipe out of the wall .  Then  screw on the following and  you get a hand shower that hangs on the  wall on a bracket and  sprays  like a shower and if you wish you can un hook it and use it in you hand. Click the link and have a  look.
Estilo Single Function Chrome Hand Shower & Connector Set WELS 3 Star Rated 9L/min  $24,57
https://www.bunnings.com.au/estilo-single-function-chrome-hand-shower-connector-set-wels-3-star-rate...
There are  more  expensive twin over head  shower, and a hand wand that has a diverter tape the either the overhead shower or  operate the hand shower wand,  This  screws in your current wall out let once you  take the old pipe off.  They  have more types and colour.
Flexispray WELS 3 Star 9L/min Black Matte Havana Short Twin Shower $362
https://www.bunnings.com.au/flexispray-wels-3-star-9l-min-black-matte-havana-short-twin-shower_p0307...
Talk to the  bunnings tool section about a good tool to use  for the insulation task
There are many showers avaliable that will suit  your needs that  will fit perfectly on your standard shower wall outlet.
Hi @elzicorn,
It's great to see you've already received advice from our knowledgeable member @Jewelleryrescue
His advice is absolutely correct, you can change just the shower head with something like this Estilo Chrome Square Shower Head WELS 3 Star 9L/min or you can also remove the pipe and use something like this Flexispray 5 Function Pulsar Hand Shower WELS 3 Star Rated 9L/min.
