What electric hot water system for a family home?
KatM
My house is a standard 3 bedroom, 1 bathroom, 1 kitchen, separate small laundry single brick veneer home, built in 1939.  I will soon be having a refurbishment done and in addition will ve upgrading the HWS.
I would like electric as I'm looking at getting rid of the remaining gas items I have (which us just the stove and HWS).
Once the refurbishment is done, I'll be renting my place out. The home is likely to fit 5-6 ppl (family) as I may also be getting an additional pod out the back.
What size HWS should I get? Ideally electric. Is a heat pump needed as well? I ask, as a few ppl have mentioned this.
What does bunnings have in the way of the above?
Does anyone know if I can also get the government rebate?  TIA
Re: what hot water system to use?
Hello @KatM
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about hot water systems.
For your 3-bedroom home that will accommodate 5-6 people, an electric hot water system (HWS) with a capacity of around 250-315 litres should be sufficient. Given your intention to eliminate gas appliances, an electric storage water heater or a heat pump could be a good fit. Heat pumps are highly energy-efficient, using electricity to extract heat from the air to heat water, which can significantly reduce your energy consumption over time. This might be particularly beneficial for a rental property, as it can offer lower running costs for tenants, which could be an attractive feature.
Bunnings offers a variety of electric HWS options, including both traditional storage tanks and heat pumps from brands like Rheem and Dux. These systems are designed to cater to various household sizes, ensuring that you'll find something suitable for your needs.
Regarding government rebates, your local government or electricity provider often provides incentives for upgrading to more energy-efficient appliances, including heat pump hot water systems. The specific rebates can vary by state and the type of system you choose, so it's a good idea to check the latest information from your local government's energy efficiency programs or the federal government's energy rebate schemes. You might also want to consult with Bunnings staff or a local installer who can provide detailed advice on eligible products and help guide you through the rebate application process.
I also suggest enquiring about the stores Hot water installation service. This will save you time and effort in regards to looking for an installer in your area.
