Hi @torabora851,
That’s a great question to raise with your installer. The 250mm ducts and diffusers are likely chosen to ensure optimal airflow, but if you’ve seen smaller ones used elsewhere, it’s worth asking whether a more compact option would work for your space. Smaller diffusers could affect airflow efficiency, but your installer should be able to advise if they can size down without compromising performance.
As for the duct running through the wardrobe, you might be able to use a smaller diameter duct or a more space-saving alternative, but again, this could impact airflow. It’s definitely worth discussing with your installer to see if there’s a practical solution that balances aesthetics, space, and performance.
