What screws to use with Carinya brackets?
amySA
Cultivating a Following
I have purchased these shelf brackets and have attached them to the wall successfully.
I am unsure which screws to use to secure shelf to the top side of the bracket as these have quite large screw holes (6mm) but am requiring a short screw.
The shelf thickness is 20mm
Any help would be appreciated
Re: What screws to use with Carinya brackets
Hi @amySA,
That's a bit of an issue for timber screws, as I'm sure you've realised. I'd recommend using Zenith 12G x 18mm Zinc Plated Self Tapper Pan Head Sheet Metal Screws. They're designed for metal, but there's no reason why you can't use them on timber, and they suit your requirements. Just ensure you pre-drill the timber (mark your drillbit with some tape at the correct depth to prevent penetrating the top side) with a 5mm drill bit.
They are panhead and not countersunk, so they will be slightly proud of the bracket instead of sitting within it.
Noyade
Re: What screws to use with Carinya brackets?
Hi @amySA  and @MitchellMc
Would these inserts be useful in this situation? Of course they would have to be a shorter length...
That would be a neat solution, @Noyade. But, the amount of work required might outweigh its benefit over a screw.
amySA
Thanks @MitchellMc I will have to give those metal screws a go. Yes very difficult to find the correct thickness for these. I stumbled across the issue during reading the product reviews from others, seems to be a common issue which is frustrating since they are a great sturdy option!
