What do i use for jamb flashing?
ashlops
Hi Team,
I am attempting to properly flash a sliding door i am installing into my carport.
I am using the following video as a guide.
https://www.youtube.com/watch?v=fCDoJwKpsBg
Its Australian and seems to follow all the proper standards.
I understand it, and how to do everything but I am stumped at 5:10 when he talks about the jamb flashing.
No one at Bunnings seems to know what this product is or have seen anything similar. Same at other hardware stores.
My question - does anyone know what this is? Its obviously a tape this is about 150mm wide, has some adhesive strip either side, so that it sticks to the frame and the sarking creating the weatherproof barrier. However, since I don't know exactly what its called I'm finding it difficult to hunt down. Any help would be appreciated!
Also, are there any alternatives I can use perhaps? Like maybe just some Alum. flashing tape that's overlapped a few times to reach the 150mm width that seems to be the AS standard?
I don't really care what I use, just so long as it creates the waterproof barrier and meets the Aus. standard.
Thanks team :smile:
TedBear
Re: What do i use for 'jamb flashing'?
Hi @ashlops
Bunnings also sell.150mm flashing, so that would be better than overlapping 2 runs of 75mm flashing.
https://www.bunnings.com.au/consolidated-alloys-150-x-0-3mm-x-10m-weatherflash_p1100453
It's great to see @TedBear has already been assisting @ashlops.
If you'd like an adhesive flashing, I'd suggest Consolidated Alloys 150mm x 10m Weatherproof Byute Flash Flashing Tape. That way, you can adhere it to the door frame and then across onto your sarking.
Thanks a bunch MitchellMC. I don't know how I missed that on the web site! A touch embarrassing! However thanks for the link up 😊👍
ashlops
Thanks TedBear.
I bought that one for the top and bottom sill flashing, but it wasn't really usable for the jamb since I needed something with an adhesive to stick to the sliding door frame and then the sarking, creating the barrier.
Regardless, thanks for your input - always appreciate any help :smile:
Hi, could you please provide tips on where to find the sill flashing tray used in the video? Thank you.
Hi @juliuspollak,
The sill tray they create in this video is made from Malthoid 2 Ply Bituminous Felt.
It is made by saturating layers of felt with bitumen. The material is then compressed and finished with a coating of fine sand to prevent sticking during handling.
You can find some more info on CA Groups website here - Malthoid Technical Information.
