Hi @Sporky,
Thanks very much for uploading those photos. Sorry that you had trouble.
You can add multiple images to a single discussion post like this one, and it's certainly better than putting them on the gallery as other community members won't be able to find them very easily there. The gallery is better used for showing off single images.
I've moved all your photos here so they are now all together. But next time, just click on the Insert/edit image button in the text editor above. I'll pop a screenshot below so you can see exactly what I mean.
Please let me know if you ever need a hand getting the most from the site. I'm always happy to help.
Aha, that makes things clearer, it looks like aluminium feet, if not polished steel, but its weight should tell you and if its rust its steel, so I doubt there will be any paint on the surface, so just clean up the surface to be glued, perhaps with a Steelo Pad/pot scourer, All the old glue needs to go. make sure the glass is perfectly clean, perhaps wipe with Metholated spirits, make sure its dry when finished, READ THE INSTRUCTIONS ON THE ARALDITE. 👍😀 apply araldite to centre of foot as well as a few dabs well in from the edge. Once you have both surfaces together, use the spatula to wipe away any excess from edge. If you think about it when applying glue try to get good amount in middle and less between that and outer ring, when you put it together the centre dolop will spread out, hopefully not past the edge if you get it right..
http://www.supercheapauto.com.au/Product/Permatex-Adhesive-Rear-View-Mirror-6mL/129940
Permatex Adhesive - Rear View Mirror, 6mL
May be suitable for attaching metal to glass ? Available at Supercheap Autos and 101 other outlets. $10.69 EACH
Adhesive
Thanks for joining in the discussion @Kanga42, and a very warm welcome to Workshop. We hope you find lots of useful information and inspiration for your projects from our community members.
To answer your other post, we allow users to edit their posts but not delete. This is to preserve the integrity of the forum and to ensure we have a record of every post made. We have now hidden your other posts from view.
Maybe try ......"Sika" Sikaflex Crystal Clear Adhesive
Thanks for joining in the discussion @vincent8. And let me extend a very warm welcome to Workshop. We're pleased you could join us and invite you to post anytime you need a hand or have something to share. Perhaps you could start by letting us know what project you want to tackle next?
Thanks again,
