Sticking aluminium to glass
Velxunai
I'm making an enclosure for small mammals out of an old 4 foot tank, but one of the panels in the tank is missing.
I was thinking about making a frame out of the aluminium "connect it" range found in Bunnings; how would I go about sticking the aluminium to the glass?
Would silicone do the trick or is there something else?
Re: Sticking aluminium to glass
Thanks for your post @Velxunai and welcome to Workshop. It's great to have you join the community. I hope you find plenty of useful information and advice here, and have some fun. I also hope a Workshop member can assist with your tank. Good luck with the project, and I look forward to reading about some of your other projects and plans.
Please let me know if you need any help getting the most from the site.
Mick
Cultivating a Following
@Velxunai
I would try something like silicone caulk. You would need to make sure you have a clean surface first, and maybe even consider roughing up the glass with wet/dry sandpaper to help it bond.
Andy_Mann
Former Community Member
Instead of using "Connect It", perhaps this instead, & as suggested silicone adhesive:
http://www.bunnings.com.au/metal-mate-12-x-12-x-1-4mm-3m-aluminium-equal-angle_p1079519
JP_Finlay
Having an Impact
@Velxunai Selleys make a liquid nails construction adhesive that is specifically designed for mirrors, metal and glass.
Thanks everyone! All this advice have been hugely helpful. I suppose using the aluminium angle would be cheaper than the connect it range so that definitely makes sense. I look forward to starting this project as its been in my garage for a few weeks now :wink:
I'll post pics of the process when I've completed it.
Andy_Mann
Way cool Velxunal, & thanks for the heads up about the alluminium angle extrusion. I'm all about DIYers saving money, because that's how I've operated, & it's very rewarding to do a great job for the least expenditure, but without compromise.
How is this project going @Velxunai?
Be great to see some photos when you have a chance.
Unfortunately I was forced to throw away the tank I was going to do this project with. We found ourselves needing to move and there was no place for me to keep such a big project :unhappy:
I hope I get to do something similar one day so I can produce photos of it.
