Porch makeover for Halloween
Renowayoflife
Becoming a Leader
4 Fun DIY projects to decorate your Porch for Halloween
Steps
Step 1
Wreath
How to Make a Halloween Wreath
https://vt.tiktok.com/ZSNhch3Ce/
A halloween wreath is a great way to add a little fun to the spooky season. They’re simple to make and can add to a full outdoor display or as a standalone decor item.
To create mine I used the following
🎃 Skeleton string lights from @ bunnings
🎃 Flower stems from @ bunnings painted with flat black @ Dulux Duramax
Wrap the skeleton lights around the wreath, I always share with lights
I cut my flowers down to a desired size and wired 3 stems together before wiring it to the wreath. I repeated this on the other side and added the black rose to hide the wire.
I added some spiders and spooky cloth I had behind the wreath across the door like a web.
Have a SPOOKTACULAR Halloween!
Step 2
Witches Broom
DIY Witches Broom
https://vt.tiktok.com/ZSNhc2Jgj/
I absolutely love this broom and this has to be one of the easiest and cheapest DIY’s.
What you need
🎃Branch from the garden
🎃Gnarly looking branches. I cut some dead branches from a tree near out house.
You can remove the bark from the branch and make the stick smooth but I loved the rustic look.
Take your gnarly branches and break them down to the desired length, try to keep them consistent.
Hold them around the branch and wind the twine until you get the desired look and the gnarly branches are secure.
⚠️ It’s best not to fly at night unless you plan to install lights.
Step 3
Ghost Candle Holder
I love how this little candle holder turned out and they’re so simple to make.
https://vt.tiktok.com/ZSNhc76Pa/
All you need is
🎃 white air dry clay
🎃 Water
🎃 Small paint brush (optional)
With wet fingers work the clay into a cylinder shape and push the candle down into the clay to shape the holder. Remove the candle then using your wet fingers or the wet paint brush smooth out the clay.
Leave for 24hours to dry. If the candle doesn’t fit snug in the holder once it’s dry heat the bottom of the candle to allow it to melt into the holder.
Step 4
Upcycled bottles & flowers
To create our spooktacular porch there were a number of items i wanted to upcycle.
What you need
Flat Black Spray Paint @ Bunnings
Faux Flowers of your choosing @ bunnings
Dolls house
Glass bottles, I used Gin and wine bottles as I wanted different shapes.
Mirror
I sprayed all of the items matte black.
To remove the labels from the bottles I submerged them in a pot of boiling water for a minute and wiped away the label.
You could also use orange or purple as an accent to the black decor.
Happy DIYing
Claire
TT
IG
Blog
Akanksha
Retired Team Member
Retired Team Member
Re: Porch makeover for Halloween
This is absolutely fa-boo-lous, @Renowayoflife! Thanks for sharing.
I love how all 4 projects you've shared are simple to make and combined, they perfectly exude spooky vibes! My favourite is that ghost candle holder - it's adorable! Will be trying it at home with my daughter this Halloween.
Thanks again for sharing such creative ideas. Can't wait to see what you tackle next.
Akanksha
