Hi, can someone give me some tips on how to patch this exposed brick and blend it in with the rest of the wall? The rest of the wall is a textured concrete veneer (I’m sure there’s a common name for it but I’m an amateur!) many thanks!
Hi @Will01,
You might like to check out this guide: How to repair a rendered wall. While your situation involves a bit more extensive damage, the same principles apply when patching the brick and blending it with the existing textured concrete veneer. You'll want to focus on applying a matching render mix and replicating the texture of the rest of the wall to achieve a seamless finish.
You might also need to use some render mesh for reinforcement to prevent future cracking. Once you’ve patched the area and it's dry, you can add a matching paint or finish to blend it with the rest of the wall.
Please let me know if you have any questions or need further guidance on materials or techniques.
