Painting prep - sanding walls
ProjectPete
Previously I've applied sealant to my walls (new house) then hand sanded it with one of these on a stick...
Problem is it's very manual and boring plus I have a whole lot of walls to sand in the new house so looking for something better.
Can I use something like this to do the job or is it too powerful? I know it can be used on gyprock to sand back the joins, but I'm talking about just sanding back the sealant on plastered walls.
TIA
Handy and helpful
Re: Painting prep - sanding walls
@Simon might be able to lend a hand on this one.
I can sympathise with the boring label @ProjectPete! Sanding certainly can be tedious business.
MartyH
Jobs like that are what apprentices are for @ProjectPete!
Have you tried just using an orbital sander? Might get a bit hard on the arms though. This Bunnings article recommends an orbital sander for plaster walls - https://www.bunnings.com.au/diy-advice/paint/paint-preparation/how-to-sand-walls
Yeah I don't see the orbital making it easier. And I still think that or the one I linked above are too strong/powerful for standard plaster walls.
Smoothing joins on plasterboard walls, sure, but not convinced I can get away from the pole sander on this one.
Handy and helpful
Brad
I think the pro's get away with fine paper using a drywall sander, they have had a lot of practice though.
For me small orbital is the go as I don't have the arms for heavy or repetitive tasks.
I have been told that using blue board you can paint over without sanding, would still need to do joins and it does cost a bit more. I will do a trial run before doing the shed lining.
