Need non-ducted rangehood for balcony
glenn1971
I live in a unit, needing too know if there is an outdoor range hood that can be installed to an under cover balcony to capture smoke smells. To stop smoke drifting too other units 🤷🏼‍♂️ Help
Re: non ducted range hood or similar
Hi @glenn1971,
Apologies for the delay in response, we have been dealing with a large volume of enquiries over the New Year period.
Yes, there are range hoods that can be installed in covered outdoor areas. Have a look at the following options -
You will need an electrician to assist with installing these products, so it's worth contacting someone before selecting your rangehood to ensure it is compatible with the location.
You can use a service such as HiPages, True Local or Airtasker to find electricians and rangehood installers in your area.
