How to unclog paint sprayer?
ivanptr
Making a Splash
Any kind of liquid i can soak the sprayer in to dissolve all the dry paint residual?
Seems there are some residuals in the nozzle which makes the spray much weaker
Its not totally blocked though
We tried using hot water to clear it (but no improvement)
Also inspected other parts seems there are no blockage
Noyade
Kind of a Big Deal
Re: Blockage issue for paint sprayer (clogged)
Hey @MitchellMc
Are there spores growing in your photo close up?
If you fill the paint reservoir with warm soapy water @ivanptr, will the machine spray it out?
Quite possibly @Noyade. Too small to see with the human eye, though.
thanks it finally finally works
the most tricky part is inside the nozzle where we cant dissemble like @MitchellMc did with wagner
Previous video: https://youtube.com/shorts/6SlptI_zqFs?feature=share
so we sticked a tiny bottle brush into the vent , and kept pressing and releasing the trigger for 30 times to make surface of that internal part scratch with our brush
we also poured some Diggers Methylated Spirits into that vent before using bottle brush, seems it did have some effect on thinning the dried paint
like @EricL said before, we need to be cautious of stronger chemical , so we didnt use acetone cos google says it can damage plastic and we are not sure if our ozito sprayer can withstand that
again, thanks heaps for both of your guidance. now i can eat my breakfast without stress☀️
That's great to hear @ivanptr!
Remember to fill the reservoir up with warm water before you finish with the machine and spray it through to clear out any paint. Also, whenever you as stopping for a couple of hours or have been spraying for a long time, clean out the internal parts so the paint doesn't dry in the unit and build up.
Good luck with the rest of your project!
