Any kind of liquid i can soak the sprayer in to dissolve all the dry paint residual?
Seems there are some residuals in the nozzle which makes the spray much weaker
Its not totally blocked though
We tried using hot water to clear it (but no improvement)
Also inspected other parts seems there are no blockage
Is that the Ozito 400W Power Paint Spray Gun @ivanptr? The ensure your spray gun performs optimally it's very important that you clean it out after every use, as once the paint dries in the ports and tubes, it's very difficult to remove the build-up. You'll find the cleaning instructions in the Ozito manual. At this stage, I'd recommend you prepare some warm-hot water with a little dishwashing detergent. Get an old toothbrush and start scrubbing all the parts. Pay special attention to any vent ports or tubes through which the paint is distributed. Use the provided cleaning needle to try and clear out the ports and vent holes. You can run the soapy water mix through the gun and spray it to see if it clears any blockages. Repeat this process until the inner workings are thoroughly cleaned. After each use, fill the paint reservoir with warm water and spray it until it runs clear before disassembling it for storage.
A port also allows air to enter the paint reservoir; if this is blocked, the paint will not be drawn out easily. This port should be somewhere on the top of where the paint reservoir is screwed onto the spray gun.
To resolve this issue, you will need to clean the unit until you find where the blockage is.
Yes, its the ozito one, do we need to open this lid ? cant find any instruction in the manual to open this lid though
Hi @ivanptr
I don't think that lid is supposed to be taken off as there is no reference on the cleaning manual. If it is permanently attached do not use force to take it off. I suggest keep using warm-hot water to pump out the clogged paint channels in the sprayer. I don't recommend using chemicals as they will damage the interior mechanism of the sprayer.
but we already sprayed it with a lot of soapy water, all visiable part, vents , filter and ports clear, just the nozzle part (in blue circle) is partly blocked and cannot be cleaned by needle or tiny brush
we are thinking to submerge the part (in red) in solvent ? like alcohol or ammonia.
but now hearing u said it might damage the sprayer, we cant make up our mind
Hello @ivanptr
As I have mentioned strong chemicals might damage the precise internal mechanism of the sprayer. I propose using thick fishing line to try and clean the nozzle of the sprayer.
In the meantime, let me ask my paint specialist at the store and see if they have more suggestions on how to clean your sprayer. As soon as I have more information, I'll get back to you.
Let me call on our experienced members @TedBear and @JoeAzza for their recommendations on possible cleaning solutions.
@EricL Thanks eric. We have stopped everything and are still looking for solution to fix our sprayer😭
Hi @ivanptr,
Take a look at the images of my Wagner spray gun below. See the white needle inside the red circle that the trigger operates? You need to clean around it, between it and the blue sheath. Paint gets sucked up from the paint reservoir, travels up the tube, and then out the blue sheath surrounding the white needle. Paint builds up in that gap directly around the needle where I've placed the red arrows. Take some wire and dig out any stuck paint in there.
The inner workings of your machine won't be exactly the same. What they do have in common is that they must be cleaned thoroughly after every use. Any paint that clogs up the mechanisms will cause the paint spraying not to work. When they are working, they are fantastic, but they do get clogged easily if you don't clean them out. I've neglected to clean mine out on several occasions. The only remedy was elbow grease and cleaning out every port and mechanism with warm soapy water until it ran again. You can see the damaged plastic around my nozzle, that's due to the wear involved with cleaning it out after every use.
If you can show me similar pictures of your nozzle unit, I can point out any paint that I think is blocking the mechanism.
it seems ozito one doesnt allow us to dissemble the tip to clean the inner needle
https://youtube.com/shorts/mZ4ARqRac5E?feature=share
https://youtube.com/shorts/6SlptI_zqFs?feature=share
some dried paint in the vent
cant clear it with soap water or a brush, might need something stronger
