How to replace a broken tile?
rajsyd
Hi there, our plumber had to break open a tile to fix a pipe joint which was hard to reach from underneath the floor and to seal it off, now it leaves 2-3 inch gap between the edge of the tile and the other side frame. There’s no support under the floor for that gap to apply some tile cement or some other material.
Can you pls suggest what would be a better approach to seal off this area so no gap exists in that area?
Re: How to replace a broken tile?
Hello @rajsyd
Welcome to the Bunnings Workshop community. It's marvellous to have you join us, and thank you for sharing your question about replacing a broken tile.
Looking at the photo you posted, it seems that the gap was just covered with a cement sheet and tiled over which is very dangerous should someone decide to step into that particular area. The proper way to repair it would be to fill the gap with concrete and then levelled before tiling over it.
I also suggest replacing the rubber coupling that has been placed in your plumbing to PVC. Concreting the rubber coupling will cause it to deteriorate and sink. I suggest engaging the services of a registered builder to investigate why this gap was left in your flooring and if it is possible to concrete the area properly.
Hi @EricL thanks a lot for your suggestions, makes sense, as the rubber coupling was just installed, we are thinking of supporting that area with sand base and rest of the area with sand+cement mix in the interim.
Raj
DIYGnome
Becoming a Leader
Concreting directly over PVC pipe will allow for zero room for pipe flex & any damage will be that much harder to access and resolve, as far as I am aware best practice dictates a layer of sand/gravel surrounds the plastic pipe to be concreted over such as under a pathway, from your picture however it appears the pipe is almost level with the nearby concrete and may not have sufficient space.
I am unable from the pictures supplied to determine whether there is any wooden sub structure adjacent to the opening, if so a supportive frame could be installed as an alternative solution, that said I would agree with EricL that this is highly irregular and in need of the services of a licensed Builder.
