How to repair Singer sewing machine wood veneer?
claire_porter
I’ve got my great grandmothers sewing machine from 1900s. The wood veneer is chipped and peeling away. Is there any way to repair this and restore the wood veneer? I found it’s continuing to worse. When I dust it the delaminated veneer catches the fabric of cleaning rags.
I’m not sure if gluing the segments back down and using wood putty to repair the missing segments is what you would do? Then how to finish the wood to seal it? If I glue the bits down will it look unsightly?
Re: How to repair Singer sewing machine wood veneer?
Hi @claire_porter,
I suspect the damage cannot be repaired but am keen to hear from some experienced furniture upcyclers in the community.
You can see how member @Cyclist replaced the top of a Singer sewing machine in similar condition in the Featured Project Upcycled Singer sewing machine as vanity.
Other members that might like to share their thoughts include @bellee78@TheSparrowHome@Renowayoflife@Poshrustic and @JoeAzza.
JoeAzza
Hi @claire_porter, I would replace the top of the sewing machine with solid timber, then stain and varnish to the finish required, or you can buy veneered wood and replaced the damaged vaneer panel. Here is a company that sells it online.
https://topveneer.com.au/
Hello @claire_porter
I'm afraid the damage is too severe, I agree with @JoeAzza's suggestion to replace the timber veneer of the machine. Just to add to the suggestions made, I also recommend looking at the 1200 x 810mm 3mm Plywood Pine Premium BC Grade as a possible alternative. to cover your sewing machine.
