I'm hoping someone can advise on how best to remove my diamond security screen from the inside (if possible). They seem to be fixed with a round headed rivet/screw (see second image). Do these have to be drilled out?
Thanks!
Hi @Mitch_1990
. Ahh I see its a fixed panel so yes those secruirty rivets will need to be drilled out or ground off and tapped out most likly.
Try pushing on the window and see where it is attached.
Hello @Mitch_1990
Welcome to the Bunnings Workshop community. It's marvellous to have you join us, and thanks for sharing your question about how to remove your window security screen.
If you are not on the ground floor, I suggest holding off on the disassembly. The security window is held in place by blind rivets and flat panels. There is the possibility that taking the rivets off will result in the outer parts falling to the ground. The window security screen is meant to be disassembled from the outside. If you are not on the ground floor, I suggest engaging the services of a handy person to take the screen off for you.
However, if you are on the ground floor the blind rivets can be drilled out and pulled out with pliers from the outside.
Thanks for the advice Eric! We'll hold off on the disassembly for now.
