Hi, can't for the life work out how to remove spindle on a Gainsborough privacy set. I'm looking for a small button to depress but this spindle does not appear to have one.
I do not know what series this set is
Welcome to the Bunnings Workshop community @adbards. It's great to have you join us, and many thanks for your question about removing a door handle spindle.
There might be a small detent in the spindle, which could require some force to pull out. I'm unaware of any small buttons that would need to be depressed. Can I ask why you want to pull out the spindle? If you want to change the handle, I suspect you've removed everything possible from this side of the door, and the next step would be to start undoing the fixings on the other side.
At the base of one of the spindles is a rubber O ring. Remove that and you can remove the spindle.
Welcome to the Bunnings Workshop community @dahern. It's a pleasure to have you join us, and many thanks for adding to the discussion.
That's a great point, and the O ring can be difficult to see and remove since it is right at the base. These Craftright 4 Piece Hook And Pick Sets come in handy for getting under the O ring, pulling it out of the grooved locating recess and back up the spindle.
We look forward to hearing all about your projects and plans around the house and garden. Feel free to reach out anytime you need assistance or have something to share with the community.
Lifesaver!! Thank you!!!!
I have the Gainsborough spindle with the small that depresses. How does it release please? I have a new one ready to go in and it has the same button but I can’t see how it releases
There is no rubber ring on this one
Welcome to the Bunnings Workshop community @markge. It's a pleasure to have you join us, and many thanks for your question about removing a spindle.
The detent in the spindle needs to be pressed down with a flat-head screwdriver or even a butter knife, which will allow it to clear the square hole of the latch assembly. Push it down and pull out the spindle in the one motion.
Please let me know how you go and if you have any questions.
There isn’t enough room to get a flat head screwdriver or a butter knife in there and I can’t even tell which side of the spindle to try??
