How to install vinyl tiles for step outside shower?
TW1
Hi! Impulsive rookie here. I bought some vinyl floor tiles for a step outside my shower - small space, just to cover some mismatching tiles - shown in photo. I then read better the part about applying the vinyl tiles over a FLAT surface, not existing tiles. These are options I have thought of with no insight into how difficult/pitfalls etc. any other suggestions very welcome:
(a) sticking piece of v thin timber plywood  on top of step, to then apply vinyl tiles to
(b) some sort of surface leveller for a small space that is easy to use??!!!
thanks for reading!
TW1
Re: surface under vinyl tiles?
Maybe some type of thin sheeting like cement type?
Welcome to the Bunnings Workshop community @TW1. It's sensational to have you join us, and many thanks for your question about installing vinyl tiles.
Given the amount of work required to install the vinyl tiles, I think it would be worth considering just tiling over the existing tiles. You'll have a much more durable surface, and it would be easier than having to adhere sheeting to the existing tiles and the vinyl tiles to that. You'll also end up with a much nicer finish as otherwise, you'd likely see the board you've used from the side.
You'd probably get away with simply applying tile adhesive right over what's there. Here's a helpful guide: How to lay floor tiles.
The sheeting you could use under the vinyl tiles might depend on how you intend to attach them. Are they self-adhesive, or will you be using contact adhesive? Cement sheeting could be an option, but it will not look particularly great on the edge. Perhaps you could paint it to blend in.
