How to install insulation (Earthwool) around downlights?
Matkai
We plan to install some boards in our roof space to store lightweight items. Before proceeding, we want to install Earthwool insulation batts.
My question is: Given that we have downlights in all rooms, do we need to cover these with special shrouds available for purchase, or can we create a barrier using foilboard to keep the insulation away from the lights while ensuring adequate ventilation?
Thank You
Re: Installing Insulation (Earthwool) Around Downlights - cover ?
Hi @Matkai,
Given the importance and safety implications of keeping insulation away from heat sources, I suggest using shrouds designed for that purpose rather than creating your own with Foil board. The additional cost of the shrouds would be worth it to not have to worry about whether your D.I.Y approach is sufficient.
Also, remember that roof timbers are not designed to bear weight, and it would be best to enlist the services of a professional to determine whether using the area for storage would be feasible.
