Hi
I bought four set of Ikonic Isabella Entrance Lever from bunning.
When i try to replace the old door level and i face some problem. The default thickness for the new Isabella Entrance Lever was 55mm and my door is 35mm. How to remove the hander and cover plate to adjust into 35mm.
Please assist as I can not find any information from the website and the manual attach.
The Isabella Entrance Lever is suitable for door thickness 35 mm to 55mm .
Thank you
Hello @tkcheong61
Welcome to the Bunnings Workshop community. It's sensational to have you join us and thanks for sharing your question about Ikonic Brushed Nickel Isabella Lever Entrance Set.
The default gap size of this door knob is set to 35mm and is supposed to be self-adjusting. I propose trying to install the unit first without changing any of its settings. You should notice that as you tighten the installation screws, it will pull the lever assembly closer together until they are at the default 35mm. Shold your door be thicker the extended screws of the door lever will compensate for the size difference. You'll also notice that the centre axle is fully extended all the way to the other lever handle. This is built to compensate for thicker doors.
