Hi All,
I've almost finished installing EarthWool R5.0 bulk batts in my ceiling; 3 bags down, I think another 2 should do it. My build recommended I also install Air-Cell foil insulation underneath the roofing tin and says it will make a huge difference (?).
I have a couple of questions, if I may, please?
Thanks in advance. New learning curve journey here.
Regards,
Hi @BoeingFan,
If it's the Kingspan Insulation 1350mm x 22.25m Air Cell Insuliner then Kinspan is the manufacturer and supplier.
Air Cell is designed for use in warehouses and commercial or industrial sheds with steel roofs and purlins. You could also use this product in your timber truss roof. There is no specific type designed solely for timber roofs.
R-values are given in the product brochure. As this product is designed for steel roofs, the R-values are provided for that specific use.
This product could be installed as a D.I.Y. project.
A note for our New Zealand members: The use of foil insulation products is prohibited.
