How to increase water pressure of multiple sprinklers?
ivanptr
Making a Splash
Our first time to deal with irrigation system because the weather is just too hot killing our lawn.. 
the problem is , to cover the whole area we need 5 sprinklers, but when we increase to 5th , the 5th one cant work well
Should we simply change the type of sprinklers for better coverage ? any solution ?
We do have one hose (which connects two sprinklers) excessively long - tomorrow I will shorten it to see if pressure increase
Re: Water pressure of multiple sprinklers too weak
Hi @ivanptr,
I'd suggest that you swap to an oscillating sprinkler that is much better suited to rectangular-shaped areas. The GARDENA Aqua S Oscillating Sprinkler has a max coverage of 17 x 13m, and the Holman Mini Oscillator Sprinkler On Base is 30 x 12m. Hopefully you should be able to get away with just the one sprinkler for your lawn.
PLease let me know if you have any questions.
