How to hang a picture without the hook showing?
Rozy
I need to hang a few pictures in my house. As most of them are glass frames, I decided to use picture hooks instead of command strips. I purchased 20kg picture hooks from Everhang. The problem is that the sawtooth hanger is at the edge of the frame which makes the picture hooks visible once hung.
 I don't like the way it looks and prefer the hooks to be invisible. Is there a way to work around this? Appreciate any ideas.
Noyade
Re: How to hang a picture
Evening @Rozy
I wonder if this would work for you (gyprock only). The 'sawtooth' connection would hang on the end. Nothing visible.
Cheers.
https://www.bunnings.com.au/everhang-plasterboard-picture-hanging-screws-10-pack_p0086520
Hello @Rozy
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about hanging a picture.
It's great that you've received excellent advice from @Noyade. I also suggest looking at the Hangman Black Double Headed Bear Claw Screws which you can use in combination with Ramset 6 x 38mm Universal Anchor - 6 Pack or the Ramset Super Wallmate Toggle Anchor
Here is a handy guide that will help: How to hang just about anything by @Adam_W.
Rozy
Thanks Noyade! Great tip.
Rozy
Thanks Eric!
