How to fix window chain?
Neo19
Making a Splash
Hello everyone,
I'm having trouble fully closing one of my windows. After taking a closer look, I noticed that the chain on this window has an irregularity at one spot, which is different from the chains on my other windows. I've attached a photo showing the issue.
Does anyone know if this is something I can fix with a simple tool, or will I need to replace the entire chain?
If replacing is necessary, is it a DIY-friendly job? Also, I'd appreciate any tips on where to find replacement chains.
PXL_20241107_233527855.jpgPXL_20241107_233537535.jpgnon-conformist linknon-conformist linkPXL_20241107_233549269.jpg
Thanks in advance for any guidance!
Neo19
Making a Splash
Re: Help Needed with Window Chain - Fix or Replace?
Just wanted to add—I initially thought some WD-40 might do the trick, so I gave that a shot. Unfortunately, it didn’t make any difference. That’s when I noticed the malformation in the chain itself.
Thanks again
Hi @Neo19,
Thank you for your question about fixing your window winder.
I'd say the pin I've highlighted below has bent or the connection between the pin and linkage itself has sheared off. Is it possible to get a photo of the underside of this linkage?
It's likely possible to replace the pin or the linkage, but you'll have to find the manufacturer of the winder to see if any spare parts are available. If you can find an identifying mark on the chain winder, I'd be happy to point you in the right direction.
Alternatively, a replacement like this Whitco Brown Lockable Window Winder is a good option that would be reasonably easy to install yourself.
Let me know what you think and if you have any further questions please don't hesitate to ask.
Hi @JacobZ
Thanks for your response.
Please find photos from underside the odd looking bit.
Hi @Neo19,
It appears that the link chain is the damaged part. A machine installs those link pins, so unlike a bicycle chain, you can't press them out and repair the section with a new link. Total replacement of the winding mechanism and chain is required.
Here's a helpful guide from @Nailbag on How to replace a broken winder winder that won't open.
Thanks @MitchellMc
I did try pressing them out without much success. :smile:
I've resigned myself to the fact that I need to replace the whole mechanism. I'm a bit bummed about needing a separate key for this window alone, though!
Thank you for pointing me to the helpful guide from @Nailbag —it looks like it will save me a lot of time.
Hi @Neo19,
Whitco's product page for the Whitco Brown Lockable Window Winder has some more information that's worth a read.
I note that the Whitco CYL4 Lockable Chainwinder I linked to above "can be matched to most door locks for one key convenience".
You may be able to get a locksmith to transfer the lock barrel over to a new winder or have the barrel keyed alike by a locksmith.
If the different key is a pain, it sounds like it's worth exploring.
Let me know what you think.
Thank you @JacobZ
I'll check out the Whitco page.
That is good to know that the chain winder can be matched to existing door locks. I'll certainly explore that option.
Take your old winder into the store @Neo19 to help match up the configuration and size. Don’t be to concerned if the mounting holes and design profile aren’t the same. It will still work itself out quite easily.
Nailbag.
