How to fix squeaky particle board flooring?
alkifaf
I have a golden opportunity to fix squeaky flooring on an upstairs landing of a two storey house, as the carpet is being replaced.
I think the floor is 18mm particle board (after reading the building information I have for the house).
I assume the boards were nailed down but won't know until the carpet comes up.
Should I use screws or nails?
I have a basic Bosch electric drill if screws. What sort of screws (and length) would I need to purchase, bearing in mind I don't actually know the thickness of the particle board?
If nails, what sort of nails?
I am in Auckland, NZ and a novice DIYer.
Re: Squeaky Particle Board
Welcome to the Bunnings Workshop community @alkifaf. It's sensational to have you join us, and many thanks for your question about squeaky flooring.
Provided the squeak is caused by the particleboard flooring not being secured properly, adding screws could help resolve the situation. I'd recommend you use Zenith 10G x 50mm Gold Passivated Square Drive Chipboard Screws. The drill you have should be sufficient to drive the screws through the particle board and into the timber supports. However, you might like to use a Macsim 10g Standard Head Clever Tool, which will pre-drill the board and add a countersink to it, allowing the screw to drive in easier and sit flush with the surface. Having the screw sit flush is important so the head can't be felt under your new carpet.
I did buy the screws, but the Macsim tool was out of stock at my local Bunnings. I purchased the P&N 10g Quickbit TCT Cut Smart Countersunk Drill Bit instead, on the advice of the store person. I wasn't sure which drill bit I should use, so choose one of the HSS. In total, I used 98 screws and next time will get the 500 pack. My observations were: I used my electric drill on too high a setting and wore out 3 x #2 drill bits. I don't think my drill has a lower enough setting and I certainly didn't realise until too late. A ratchet type screwdriver did the job perfectly well, although slowly. I also broke the 2 x HSS bonus drill bits, don't know how or why, so I completed the job with the TCT drill bit.
