How to fix bulging near load bearing wall?
patni209
Hi, I would like to have an advice regarding issue we are facing. We have recently bought this house 3 years old, load bearing wall separating lounge and room there is passage. Both sides of wall there are multiple bulging showing up. Would you please advise what could cause this and any recommendations for solutions would be much appreciated.
Thank You
Re: bulging near load bearing wall both sides
Good Evening @patni209
I couldnt see any leaks in my roofing either, then after seeing drops form I knew I really should have a second look and a third. I still have not tracked down where the drips are coming from. (pretty much that sometimes it takes someone who deals with these issues to know what the small signs are)
As to suggestions about finding a builder, here are a few that I have used.
Ask workmates, ask friends who they have used. Best way to find someone decent as your friends will give you theier opinon for sure :smile:
Jump into the big blue social medial F pages, Search withing F pages and all of a suddern your newsfeed will be filled with builders, especially from your local area. I use the algorithum for my own benifits :smile:
Once you find one either on recomendations or in facebook land, have a look at their jobs/photos. I know they will only post the better ones but still its a way to see how decent they are.
Doing the above will find you someone local, prob not the cheapest but definently someone you have seen their work. I think its a wise move to have a "builder", a "sparky". a "plumber", and a "carpenter" in your list of tradie mates :smile: Treat them right on their first job, give a hand if they let you and at the very least they will remember you for the next thing you have. I have a carpenter/builder mate and a plumber mate, both Ive met through work contacts :smile:
Thank you Dave,
would you please help me getting  your builders details for an advise to come have a look.
much appreciated
Morning @patni209
Sorry it dosnt work that way :smile:
You and I could be anywhere between Aus and NZ :smile: or even potentially anywhere.
This is somthing that you will start with as they will be your "go to" trades when possible.
Id pick say a carpenter to start with, then if you are happy with them ask if they know a plumber or sparky. They will know for sure and they will also know for your area :smile: Its a matter of being friendly, being procative as in making clear decisions and discussing with them. You build up a relationship with them.
Hi @patni209
When searching for a builder make sure they are a "registered builder" who will have a registered number. This qualification is chalk and cheese to a carpenter who are also commonly referred to or refer themselves as a "builder".
Another place to start other than @Dave-1 suggestions is to drop into a local building approvals company. They work with registered builders every day and will be able to steer you towards a few recommendations.
Regards Nailbag
