Hi I couldn't actually see what I needed in the category section but I'm looking at fitting out a Hyundai iLoad van as a camper van and I'm wondering whether anyone has any ideas about this
I've just spent a lot on the van itself so I would like to fit it out as cheaply as possible
Hi @hotsprit
Your project sounds great. I think the best plan is to research and look at many other camper examples and make a collection of ideas. This will lead you on to what materials to use and the tools and fixings you need. At this point you can explore alternate lower cost materials if you wish.
When you know your planned inclustions you wish to have you may also find components and appliances on sale if you have a list.
Start your plan with insulating ideas as it will be important to plan ASAP into your design.
If your handy I might make the cupboards and framing out of pine as it is realitvly light weight yet strong enough and flexable material for starters.Easy to fix to and clad.
Divide your project up into bite size chunks so the whole project dosnt over welm you with a 1000 option all at once.
Hello @hotsprit
Welcome to the Bunnings Workshop community. It's wonderful to have you join us, and thanks for sharing your question about fitting a camper van on a budget.
It's great that you've received excellent advice from @Jewelleryrescue. Just to add to the suggestions made, I recommend thinking about the basics you want available in your van.
One of the most basic layouts is to have the bed off the van floor with a timber frame and the space underneath will serve as the storage space. This would be the most budget friendly as you can use the Montgomery 34L Clear Underbed Storage Container - 34L as a storage container and line them up underneath.
However, if you are after a more complex layout, I suggest drawing your ideas on paper. You can then quantify what materials you'll need.
I also suggest having a look at these discussions:
