How to fill in or cover a plaster ceiling vent
iinsaayn
Hi. This is my first question to this forum.
My house was built in the 60s and has 2 plaster ceiling vents - one in the bathroom and the other in the kitchen. The bathroom vent in particular let's in the horrible paper mulched insulation dust as well as spiders. I'm looking for ways to cover them up without them looking super ugly. The ceiling spaces are difficult to get into to cover them from within the roof cavity, so I don't want to do that. I've thought of a painted board, plasterboard, plastic type board, but don't know what would be best. I'll attach a photo of the kitchen vent, but they're both the same.
Re: How to fill in or cover a plaster ceiling vent
Hi @iinsaayn,
In covering them up, they would no longer be able to act as a vent. Are you fine with this?
If so, the easiest way I can see is to remove them and patch the ceiling.
Have a look at my colleague @EricL's advice in How to fill hole from ceiling fan and my advice in What exhaust fan for 290mm square cut out?
This same process of using timber to back block the patch, installing plasterboard, plastering and painting could be used in your situation.
Let me know what you think, I'm happy to offer further advice if you have concerns or questions.
I have had an electric ceiling fan installed in the bathroom. The kitchen doesn't need it either.
I was hoping not to have to do such a big job.
Hi @iinsaayn,
The easiest solution I can think of would be to cut a square piece of plaster and adhere it to the middle section with Liquid Nails. It will need to be large enough to span over the gaps and meet the sides. You can then use gap filler to seal it around the edges.
I've added a rendering below to illustrate.
Thanks Mitchell. That's what I was thinking but hadn't considered liquid nails. Was going to use plasterboard screws. I think I'll try you idea. Thanks.
