How to enlarge set back hole for door knob?
Coolaholigah
Building a Reputation
Hi and thanks in advance.
I have purchased a passage set door knob (https://www.bunnings.com.au/ikonic-brushed-nickel-ruby-passage-set_p0199993) and am hoping to change over from an old one. The hole needed for the new one is larger than the existing. I have a drill bit for the right size hole but how do I line it up and make sure it’s in the right place? It looks from the instructions like the new knob only has screws in to the door on one side and also horizontally so the existing screw holes shouldn’t be a problem. Is that right? Thanks
Re: How to enlarge set back hole for door knob?
Hello @Coolaholigah
Thanks for sharing your question about your new doorknob. Inside the packet of the Ikonic Brushed Nickel Ruby Passage Set is a tightly folded set of instructions along with a cutting template. All you need to do is cut out the template guide and paste it to your door and you'll see exactly where you need to cut to fit your new doorknob.
My best advice is to make sure that the new hole is lined up with the latch set currently in your door.
Here is a link to the installation instructions: Ikonic Passage Set.
Coolaholigah
Oh. So you kind of drill through the paper?
Hi @Coolaholigah
It's best to mark it with a pencil or marker if possible, drilling through the paper will tear it to shreds and you'll loose your guide.
Coolaholigah
The https://www.bunnings.com.au/ryobi-wood-door-lock-installation-kit_p0252336 installation kit turned out to be a worthwhile investment though I didn’t understand how to use the spade bit guide. The guide was most useful for drilling the 54mm hole because with the existing hole the pilot drill was not usefulAfterAfter
all done
Love your work, @Coolaholigah! Well done.
