How to clean and refresh a vinyl chair?
ilox
Cultivating a Following
So here is the throne in its better days.
Now it is looking worse for wear. The seat has golden-ish metal buttons with metal loops. They show tarnish.
The surface of the vinyl also shows black spots that I hope can be cleaned.
Suggestions please?
The back had lovely plastic buttons from Spotlight. Every single one of them has given up and fallen off.
Now, that is going to take a lot of work, fixing new metal buttons and getting it clean and tidy too.
The cushions on the arms get a lot of use each season and they need to be cleaned up as well.
Any advice would be much appreciated.
PS: No, I don't think it is possible to replace the vinyl unless necessary. That stuff is not cheap and no, it was from a professional automobile upholsterer, not Bunnings or Spotlight or other handyman stores.
Re: Fixing up Santa's Throne - part 2 - Cleaning and refreshing the Vinyl
Hello @ilox
I believe the leather surface can be cleaned by using dishwashing liquid in combination with a soft sponge. You don't want to use anything too rough as it will damage the vinyl cover. In regards to the buttons, would it be possible to replace them with Pinnacle Brass Hammer Head Upholstery Nails? Putting them into the original position of the buttons should save you from having to drill into the timber backing.
ilox
Thanks, Eric, I think I am going to need something stronger than dishwashing liquid to get the stains off but that would be a good start to get the black stuff off. Maybe some sugar soap would shift it? I will also need a good creme to feed the vinyl and keep it supple.
As for the pins. Hmm, I already have holes in the back board where I ran the heavy cord to hold the button in, so the space behind the pins is compromised with a 3mm hole. I think I will need metal gold-ish buttons, similar to the ones used for the seat, with a metal loop so they won't snap off and fall out.
Sugar Soap sounds like it would be worth trying, @ilox. Do a test section in an inconspicuous location to ensure it doesn't discolour the material.
You might like to try some Mechanix 1L Auto Protectant, which is suitable for vinyl. Once again, do a test section.
ilox
Thanks, Mitchel, will see how I go with getting it cleaned up.
ilox
Well I took off the padded section from the frame, only to find an ant problem, little black ones this time.
Back of the back panelBack of the back panel
This was the back of the back panel. It was ruined by water incursion. The strings are for the front buttons, the buttons that all gave up because they only had a plastic shank.
Black ants nestingBlack ants nesting
But further down was an active Black Ant infestation, eggs and all. There were all through the foam padding too. I had to throw everything out, foam padding, plywood panel, the lot.
Now I have to start from almost fresh, the vinyl will be reusable after a decent clean.
I need to buy some foam padding. Any suggestions please?
Hi @ilox,
I'm sorry to hear you're experiencing more issues with your throne.
You could use Bastion 1200 x 600 x 50mm XPS Multi Use Foam Board, but it isn't the softest foam.
There is also these Eva 50 x 50cm Black Solid Interlock Foam Mats which are softer but quite thin.
Maybe a combination of the two would work?
Let me know what you think.
ilox
Thanks for the ideas. Both of those would be too firm for this. It would need to be one of the more flexible compressible foam sheets. I think I got the originals from Clark Rubber in Modbury. Not sure where else I could get foram for upholstery?
