How to change evaporative cooling air vents?
antrix_bansal
Hi i have an evaporative cooling unit and i am looking to change the vents. What are the available options ?
JDE
Becoming a Leader
Re: How to change evaporative cooling air vents?
Most domestic set ups are the same as you have. There are also round diffuse ones or square ones that radiate from the centre. Bunnings has a range from both Bradford and Haron. I suggest you google Bunnings Aircon Ceiling Vent. Personally I like the look of the round ones but they reduce your ability to direct the air. By pushing the squares up and pivoting them you can direct the air with the ones you have. Also with yours you can cover each of the four sets of slats with clingwrap or a freezer bag and put them back in, in winter greatly reducing heat loss. JDE
Re: air vents
Hi @antrix_bansal,
As @JDE has already mentioned, there is a variety of ceiling vents that you can check out on our website.
Some vents snap in place without any fixings, whereas some utilise a bracket and a screw. Assuming you can find a vent with the same dimensions, you should be able to just remove the old one and replace it, utilising the same hole.
Let me know what you think.
