How to build support piers for small house extension?
Ext54
I’m removing an old leanto extension and building a slightly larger enclosed verandah extension using Uni-pier piers. The proposed extension is 3600 by 2700. I will concrete the piers into the ground 450mm, just wondering what dimensions the hole should be?
Re: How to build support piers for small house extension?
Good morning @Ext54
Welcome to the Bunnings community page :smile: Its a nice place to find a bunch of informnation and ideas.
I have not used Uni-pier piers before but have dug plenty of foundation holes for piers.
I have used a
Square Mouth Shovel as it was the perfect size to get down into the hole and have straight walls with it, I could drive the shovel down into the clay to crack off the next inch or so of soil. I havnt really used a post hole shovel (As in a narrow width shovel) before. The holes I have dug have been between 450mm-600mm.
Ext54
Thanks for that Dave, that’s about the size I was expecting. I haven’t dug any holes for investigation yet but I think your info is spot on.
Good afternoon @Ext54
Hey just remembered to warn you of stormwater pipes especially near the foundations of the wall. I have run into that issue before.
Hello @Ext54
Allow me to welcome you as well to the Bunnings Workshop community. It's marvellous to have you join us and thank you for sharing your question about Uni-Piers.
It's great that you've received excellent advice from @Dave-1. Just to add to the suggestions made, I recommend calling the BYDA (Before you dig Australia) just to be sure that there are no electrical or plumbing utilities in the area. Since you are building a larger structure with larger piers, I suggest consulting a structural engineer to get an opinion on how large and deep the foundation holes should be.
The engineer will probably ask you if you have a sketch of your plan and the size of the timbers you'll be planning to use. Any other information you can provide will definitely be helpful.
Here is a link to the Uni-Pier Brochure: Uni Pier Selection Guide
If you have any other question we can help with, please let us know.
Ext54
Thanks Eric 👍👍👍
