Hi All I am a total DIY novice. So reaching our to all the gurus in here for guidance. I have got a unusual project. We are wanting to build a L shaped enclosure in our living room for where we keep our pet cockatiels and budgies. The enclosure we are wanting is around waist high with a base running from two walls and intersecting in an L and a clear material waist high L shaped enclosure stting on the base. The aim is to prevent the seed debris etc from the birds rolling across the entire living room. I am wanting guidance on how build this. I am imaging two pieces intersecting in a L and then something other than glass forming the 'wall' of the enclosure. I have enclosed two photos of the area which we want to bound by the enslosure. I am probably not very clear in explaining what we are after so thanks in advance for the help.
Hi Partha (@PN),
I'd suggest that you'd need a drill driver and a handsaw or circular saw.
Depending on how far your birds throw their seed out of the cages, I would have thought that an enclosure made from a piece of 285 x 19mm x 2.4m Premium Grade Dressed Pine would capture 95% of debris. 285mm would be over half the height of the cage and if it setback away from the wall I don't see the birds throwing seed at that angle. That would certainly be easier to construct than the framed version I previously mentioned.
Hi Mitchell
thank you so much. This is very helpful and more manageable for a novice like me ! With from a piece of 285 x 19mm x 2.4m Premium Grade Dressed Pine to build the enclosure so saw the wood into two pieces ...
Thanks
Partha
Hi Partha (@PN),
There are no silly questions here and you're more than welcome to ask as many as you like. We're here to help.
@MitchellMc will be more than happy to assist when he's back on the site on Friday. Thanks so much for your patience in the meantime.
Stevie
Many thanks Stevie and good to e-meet you.
Thanks
Partha
Hi @MitchellMc Mitchell
I have ventured into the store and got the following.
Pine-dressed premium grade of 285 mm x 19 mm x 1.2 mm - 3 pieces of this.
Zenith 8G x 15 MM Galvanised Button Head Stitching Timber Screws - 100 pack
Carinya 140 x 40 x 40 x 2 mm hot-dipped galvanised Builders angle
The screws and the angle was recommended by the Bunnings in-store trade team in Warragul.
My question is Mitchell what sort of drill do I need to use for the wood screws?
Also because I have bought a smaller length timber. I now need to join the two length pieces of the L - what sort of angle or hinge should I use Mitchell to join these two pieces?
I will use the angle I have purchased to create the L shape.
Many thanks
Partha
Partha (@PN),
A drill driver would be the correct tool to use for wood screws. However, you could get by with just a screwdriver.
To join the two timber sections to become one longer piece, you'd need to use something similar to a Zenith 75mm Zinc Plated Mending Plate. Alternatively, If you had a small scrap of timber that could also work, you'd screw through it into the two pieces you want to join.
Many thanks @MitchellMc Mitchell. I will get both and give it a go at putting it together.
Thanks
Partha
